16 years agoUsing external flash drive
I've designed my system with CFI flash interface. It uses the DE2 on-board flash memory. This is not enough storage for me though. How would I configure my device to use an external flash drive inser...
16 years agoEdit the Interface and Signal column of the Signals tab in the component editor. The OTG signals should be a conduit type with the signal being export.
irq and irq need different interrupt sender interfaces. Then edit the signal interfaces to associate the proper interfaced to the interrupt. You may need to hit the "Remove interfaces with no signals" button on the interfaces page.
