16 years ago
Using Compact Flash
I've got an ext3 formatted Compact Flash on a Cyclone II Eval Board.
At the Nios Wiki
http://nioswiki.com/operatingsystems/uclinux/compactflash
It tells you to select the
[*] Generic Platform
When I select this I get the following "make" error(s):
ln -sf staging-pkg-config tools/nios2-linux-uclibc-pkg-config
rm -f /home/janet/nios2-linux/uClinux-dist/linux-2.6.x/usr/initramfs_data.cpio.gz
make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/janet/nios2-linux/uClinux-dist/../linux-2.6 O=/home/janet/nios2-linux/uClinux-dist/linux-2.6.x -j4 zImage || exit 1
make[1]: Entering directory `/home/janet/nios2-linux/linux-2.6'
no emulation specific options.
GEN /home/janet/nios2-linux/uClinux-dist/linux-2.6.x/Makefile
scripts/kconfig/conf -s arch/nios2/Kconfig
CHK include/asm-nios2/nios2.h
perl -I/home/janet/nios2-linux/linux-2.6/arch/nios2/scripts /home/janet/nios2-linux/linux-2.6/arch/nios2/scripts/gen_nios2.h.pl cpu ddr_sdram < /home/janet/nios2-linux/CycloneII_files/17Sept10-CYCII/NiosII_cycloneII_2c35_full_featured_sopc.ptf > include/asm-nios2/nios2.h.tmp; if [ -r include/asm-nios2/nios2.h ] && cmp -s include/asm-nios2/nios2.h include/asm-nios2/nios2.h.tmp; then rm -f include/asm-nios2/nios2.h.tmp; else echo ' UPD include/asm-nios2/nios2.h'; mv -f include/asm-nios2/nios2.h.tmp include/asm-nios2/nios2.h; fi
CHK include/linux/version.h
CHK include/linux/utsrelease.h
SYMLINK include/asm -> include/asm-nios2
Using /home/janet/nios2-linux/linux-2.6 as source for kernel
CALL /home/janet/nios2-linux/linux-2.6/scripts/checksyscalls.sh
GEN usr/initramfs_data.cpio.gz
CHK include/linux/compile.h
CC arch/nios2/kernel/config.o
unknown file type line 128: 'n##od'
AS usr/initramfs_data.gz.o
LD usr/built-in.o
CC drivers/ata/pata_platform.o
/home/janet/nios2-linux/linux-2.6/arch/nios2/kernel/config.c: In function `cf_init':
/home/janet/nios2-linux/linux-2.6/arch/nios2/kernel/config.c:782: warning: initialization makes integer from pointer without a cast
LD arch/nios2/kernel/built-in.o
LD drivers/ata/built-in.o
LD drivers/built-in.o
LD vmlinux.o
MODPOST vmlinux.o
WARNING: modpost: Found 2 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
GEN .version
UPD include/linux/compile.h
CC init/version.o
LD init/built-in.o
LD vmlinux
__pata_platform_remove: discarded in section `.devexit.text' from drivers/built-in.o
make[2]: *** [vmlinux] Error 1
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/janet/nios2-linux/linux-2.6'
make: *** [linux] Error 1
IF I SELECT:
[*] Altera SOPC Builder CompactFlash support (Experimental)
I successfully compile.
So, a few questions:
1. WHY CAN'T I COMPILE WITH THE "Generic Platform" selected
2. Is the "Altera Sopc Builder CompactFlash support" stable ?
The reason I ask this is because I was monitoring the writing to the CF and my interrupt of the data coming into my board and it appears that the IRQs are getting TURNED OFF for up to 13 milliseconds some times !!!
So, question
3. Does the "Altera SOPC Builder CompactFlash" driver TURN OFF INTERRUPTS ?
Thanks in advance
