16 years agousing char-lcd in linux
hi, when i compile the kernel ,error occurs: na_lcd_16207_0 undeclared How can i fix it thank you wangweike
16 years ago --- Quote Start --- Me tip is usefull for a system without a mmu. I think the + 0x8000000 is not needed with a mmu based system. Is jou system running and you can compile linux? --- Quote End --- yes,everything goes fine,except adding lcd
