21 years agoUsing alt_flash_open_dev
Hello, I have a Nios2 system that runs from flash (flash = program memory). My program needs to access flash at a certain moment, it needs to write/read some data to it. The alt_flash_open_de...
21 years agoHello,
I understand the problem with the status bits (I have read the post from Scott). That's why I have placed my FlashAccess function in FPGA internal memory (by using a section attribute). My FlashAccess function uses the alt_flash_open_dev function and the problem is that this function is still located in the flash. Do you know how to place the alt_flash_open_dev function in a section in FPGA internal memory? You suggest to read from the address, can you explain me how to do that? (or where I can find an example?). thanks and best regards, Dolphin
