12 years agoUsing alt_flash_open_dev with 'enable_reduced_device_drivers'
I'd like to use on-chip RAM (69KB) for a small nios app to execute in-system-programming code. The only way I could get the code to fit is by enabling the reduced driver option. The problem I...
12 years agoYou also need to allow for the stack any malloc()ed data. The latter will be considerable....
Getting the bit-bang timing valid is easy, the most you'd need to do is write the same value to the io port a few times. However a 100MHz nios probably can't do things too quickly anyway, especially since Avalon bus writes are synchronous (unless they've changed that for teh new version). The 'memory utilisation' of 33% only include the used parts of the memory blocks - even though the rest of the blocks is typically unusable.
