11 years agoUsing a bootloader for NIOS II, nios2-elf-objcopy creates very large object file
Hello, I've an NIOS II application builded via the command line tools. I've now decided to run the program from the onchip_mem instead from the flash. Reading the AN458, it is clear that the ...
11 years agoSounds like you have initialisation data for disjoint memory areas.
look at the output of 'objdump -h' and 'objdump -p' - these should tell you which memory areas are being initialsed. At a guess you are trying to place code at the reset vector location.
