16 years agousing µclinux in board 2C35
hello, I followed the step of the http://www.nioswiki.com/linux after this steps i arrived to 3. The images created are, images/linux.initramfs.gz is the elf image with initram...
16 years agohello,Hippo
thank's for your help juste when i followed the step in http://nioswiki.com/operatingsystems...uartusforlinux (http://nioswiki.com/operatingsystems/uclinux/quartusforlinux) i setup a shell "n2sdk" ,i creat it in /opt for the "n2sdk" i juste change export PERL5LIB=/usr/lib/perl5/5.10.0 by export PERL5LIB=/usr/lib/perl5 because i work with ubuntu 8.4 when i execute ./n2sdk [NiosII EDS]$ quartus bash: quartus : commande not found /opt [NiosII EDS]$ also [NiosII EDS]$ jtagconfig bash: jtagconfig : commande not found /opt please if you have any solution for this problems juste for information i use quartus II 9.1 (beta) .
