16 years agousing µclinux in board 2C35
hello, I followed the step of the http://www.nioswiki.com/linux after this steps i arrived to 3. The images created are, images/linux.initramfs.gz is the elf image with initram...
16 years agoPlease unzip the zip file. There,
NiosII_cycloneII_2c35_full_featured.sof is the fpga configuration file, 2c35 with nios2 MMU. zImage is the kernel You should follow http://nioswiki.com/operatingsystems/uclinux/quartusforlinux to setup a shell script "n2sdk". Then run the commands under n2sdk. - Hippo
