16 years agoUse uClinux on my own design
Hi all, I was able to successfully configure uClinux for my NEEK board, and run some demo applications on it. Now, I have to make all of this work on a board that we designed in the office. I ...
16 years agoSorry. I have no knowledge at all about "Frame Reader" :(. What is this ? I did some initial test with VNC and was able to transfer some picture data via TCP/IP to the PC, but I did not try yet to link this picture buffer to Nano-X.
But when modifying the function of a device usually means that the Kernel driver needs to be modified. Here the frame Buffer driver used by the NEEK Linux distribution uses the SGDMA's programmer's interface. If you replace that, the driver will not work any more. -Michael
