19 years agoUse of timer in Nios
I have beginner level question about using timer in Nios. In timer datasheet there is an example:# include "nios.h"
int main(void) { int t = 0; // Set timer for 1 second na_timer1->np_timerperiodl = (short)(nasys_clock_freq & 0x0000ffff); na_timer1->np_timerperiodh = (short)((nasys_clock_freq >> 16) & 0x0000ffff); // Set timer running, looping, no interrupts na_timer1->np_timercontrol = np_timercontrol_start_mask + np_timercontrol_cont_mask; // Poll timer forever, print once per second while(1) { if(na_timer1->np_timerstatus & np_timerstatus_to_mask) { printf("A second passed! (%d)\n",t++); // Clear the to (timeout) bit na_timer1->np_timerstatus = 0; // (any value) } } } When i compile and run this it works fine. But in my own application i nee timer that counts 455us not to 1 s. and i tried to change timerperiod register values. Th way I understood, they have used timer period of 33.333.000 in nasys_clock freq, which gives a time of 1 s. When i try to change it for example 15167 which is approx. 455us, there is a compiler error which says "parse error before '=' at the lines where i try to change the timer value. I tried it with the same timer example but with the different value: # include "nios.h"# define count_time = 15167 int main(void) { int t = 0; // Set timer for 1 second na_timer1->np_timerperiodl = (short)(count_time & 0x0000ffff); na_timer1->np_timerperiodh = (short)((count_time >> 16) & 0x0000ffff); // Set timer running, looping, no interrupts na_timer1->np_timercontrol = np_timercontrol_start_mask + np_timercontrol_cont_mask; // Poll timer forever, print once per second while(1) { if(na_timer1->np_timerstatus & np_timerstatus_to_mask) { printf("A second passed! (%d)\n",t++); // Clear the to (timeout) bit na_timer1->np_timerstatus = 0; // (any value) } } } It suddenly doesnt work? What's the problem? Thanks! -jarkko2 Replies
Hi jarkko,
> What's the problem? -# define count_time = 15167 +# define count_time 15167 Regards, --Scott - Altera_Forum
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif ehhhh.... thanks!
-jarkko
