21 years agouse mac without using jtag
hi all, i have a problem. on my 1c12 board i wanna use the mac without using the jtag. the mac only works after i start the terminal and the linux load up. it should work this way: reset -> acc...
21 years agoWhen you use the JTAG UART, the kernel is susspended until you open a nios2-terminal.
Search the forum t, there are a few posts that tell you how to fix this problem by disabling the JTAG UART in the Kernel and then enabling/using the Serial UART. Hope this helps.
