15 years agouse command prompt ?
Hello I have a code in c++ .I execute it with command prompt I turn it under NiosII , the compile successful. How I can execute it under Nios II with command prompt? Can ...
15 years agoConsole functions available through jtag_uart are for example:
printf(..) : print formatted string on the console pan getc() : get input data from console You can't transfer a file from your pc's hd to the Nios, if you mean this. I know there's a way to transfer files but I don't know how to do it. Search the Altera website and forum and you'll probably find it. If you really need the script.txt and this is constant, a simple way to do it is incorporate the file content into your code.
