21 years ago
USB kernel config
We're using the Cypress SL811 host controller on our NIOS2 board. The kernel config option wasn't available until I edited the Kconfig file in the source tree (drivers/usb/host/Kconfig), found the appropriate option, and added
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
|| (NIOS2 && USB)[/b]
--- Quote End ---
You guys really need to go through and update the stuff which is in there to make it available. :-)
Or does this stuff only work in NIOS 1 but not NIOS2? (I haven&#39;t compiled yet.)
This was the case with all USB support too, you may recall.
    The one I spent time on is the old driver. It worked only for 2.6.5, not for 2.6.9. I am supposed to switch to the new driver, but have not got time. But with the new driver, you should have little problem.
    Ah, gotcha.
    Interesting word, "should". :-)
    I&#39;m trying to add the appropriate lines to set up the resource to setup.c as follows:
    static struct resource sl811_resources = {
          .start  = 0x48389D0,
          .end    = 0x48389D3,
          .flags  = IORESOURCE_MEM,
          .start  = 0x48389D4,
          .end    = 0x48389D7,
          .start  = 7,
          .end    = 7,
          .flags  = IORESOURCE_IRQ,
    static void sm3k_port_power(struct device *dev, int is_on) {
        // see linux/usb_sl811.h
    static void sm3k_hc_reset(struct device *dev) {
    struct sl811_platform_data sm3k_sl811 = {
        .potpg = 100,
        .port_power = sm3k_port_power,
        .reset = sm3k_hc_reset,
    static struct platform_device sl811_device = {
        .name           = "sl811-hcd",
        .id             = -1,
        .dev = {
      .platform_data = &sm3k_sl811,
        .num_resources  = 3,
        .resource       = sl811_resources,
    and then down in the setup_arch() function in arch/nios2nommu/kernel/setup.c (right before the
    printk("Done setup_arch\n");
    I added
    platform_device_register(&sl811_device);
    But when the kernel boots, I get
    --- Quote Start ---
    <3>sl811-hcd: failed to claim resource 0[/b]
    --- Quote End ---
