19 years agoUSB ISP1362 has some problem.
Hi, everybody
I'm a newbie for Nios2 uClinux. I used uClinux-dist20060803 distribution and DE2 target board. It's ISP1362 USB driver has somw problem. Can someone please help me? ~"~ Regards faye2 Replies
hi
I think that you should describe your problem in detail http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif - Altera_Forum
Hi , everybody
I used uClinux-dist20060803 distribution and DE2 target board. I following your "WiFi" try out wireless dongle (GW-US54GZL driver) it can not work. (1) I used thumb USB testing the "UsbHost" (USB ISP1362 driver) , that it can be able to access, so it's ok. (2) I used Linux PC testing the "USB Wireless Dongle" (GW-US54GZL driver) it's ok. (3) When I try out wireless driver with "GW-US54GZL_Linux_v.2.15.0.0_CE.diff" ,it can not work. display following message: vendor_id = 0053 product_id = 5301 USB 1.1 Host Release Ver = 4810 EEPORM Ver = 4810 Finsih download Firmware. Ready to reboot PA type: 0 PHYNEWLayout = 1 Airoha AL2230S_RF AllowedChannel = 000107ff Region:16 usbcore: registered new driver zd1211b /> ifconfig eth0 up /> iwconfig lo no wireless extensions. eth0 no wireless extensions. eth1 no wireless extensions. /> ifconfig eth1 up /> iwconfig lo no wireless extensions. eth0 no wireless extensions. Warning: Driver for device eth1 has been compiled with version 20 of Wireless Extension, while this program is using version 17. Some things may be broken... eth1 802.11b/g NIC ESSID:"" Mode:Managed Frequency:2.442GHz Access Point: 00:00:00:00:00:00 Bit Rate:1Mb/s Retry:off RTS thr=9999 B Fragment thr:off Encryption key:off Power Management:off /> It can not receive any Access Point ? Please help me! Hippo say that it's ISP1362 USB driver has some problem. Regards faye
