20 years agoUSB device!
I have a usb flash disk, I want to using it on my board, I choose USB Mass storage and SCSI disk and ISA116X driver support in menuconfig. Start uClinux on NIOS II SDK shell, using dmesg, I got these message:
# dmesg Linux version 2.6.11-uc0 ([email protected]) (gcc version 3.4.6)# 11 Sa t Apr 15 17:52:30 CST 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 008F0000 On node 0 totalpages: 2048 DMA zone: 2048 pages, LIFO batch:1 Normal zone: 0 pages, LIFO batch:1 HighMem zone: 0 pages, LIFO batch:1 Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6188k/8192k RAM, 0k/0k ROM (1334k kernel code, 551k data) Calibrating delay loop... 24.72 BogoMIPS (lpj=123648) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler deadline registered dmfe_probe:eth0, 50000 Khz Nios <DM9000> eth0 I/O: 80900090, VID: 90000a46 ADDR: 00:07:ed:00:00:00 dmfe_probe:eth1, 50000 Khz Nios Linux video capture interface: v1.00 116x: driver isp116x-hcd, 08 Apr 2005 116x: ISP116x Host Controller, irq 4 isp116x-hcd isp116x-hcd: new USB bus registered, assigned bus number 1 116x: Invalid chip ID 3630 isp116x-hcd isp116x-hcd: USB bus 1 deregistered 116x: init error, -19 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) NET: Registered protocol family 1 NET: Registered protocol family 17 Freeing unused kernel memory: 436k freed (0x15e000 - 0x1ca000)# I plug my usb flash disk in my board usb host port, there is no message appear! How could I to find the usb disk?43 Replies
Hello...
Please Help as I think you people can.. I am curently working on IP08 board made by Rowetel and it has BF532 and ISP1362 controller for USB. The Problem I am facing is that I am able to use normal USB Mass storage devices they are detected by the system (uClinux 2009 dist). i.e. it prints a message saying usb 1-2: new full speed USB device using isp1362-hcd and address 2 usb 1-2: configuration# 1 chosen from 1 choice scsi0 : SCSI emulation for USB Mass Storage devices usb 1-2: New USB device found, idVendor=0951, idProduct=160b usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-2: Product: DataTraveler2.0 usb 1-2: Manufacturer: Kingston usb 1-2: SerialNumber: 0802101904166 uncorrectable error : <3>uncorrectable error : <3>uncorrectable error : <3>unco2 sd 0:0:0:0: [sda] 7806847 512-byte hardware sectors: (3.99 GB/3.72 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Assuming drive cache: write through sd 0:0:0:0: [sda] 7806847 512-byte hardware sectors: (3.99 GB/3.72 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Assuming drive cache: write through sda: sda1 sd 0:0:0:0: [sda] Attached SCSI removable disk and at this point root:/proc/bus/usb> cat devices T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2 B: Alloc= 0/900 us ( 0%),# Int= 0,# Iso= 0 D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64# Cfgs= 1 P: Vendor=1d6b ProdID=0001 Rev= 2.06 S: Manufacturer=Linux 2.6.28.10-ADI-2009R1.1 isp1362-hcd S: Product=ISP1362 Host Controller S: SerialNumber=isp1362-hcd.0 C:*# Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA I:* If#= 0 Alt= 0# EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 4 Spd=12 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64# Cfgs= 1 P: Vendor=0951 ProdID=160b Rev= 1.00 S: Manufacturer=Kingston S: Product=DataTraveler2.0 S: SerialNumber=0802101904166 C:*# Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA I:* If#= 0 Alt= 0# EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms But when I try to attach MP3 Player or Nokia Phone it does not even show symptoms of being attached to usb port. Although I have compiled ISP1362-HCD and enabled the cdc-acm support as well. Kindly guide me whether it is feasible or not, If yes then where the problem is. - Altera_Forum
TO_BE_DONE
Hi.I have a DE3 board.I want to use the USB interface in the DE3 board,How can I do it.I add ISP1760 to my design and compile successed.Is there anything should be modified?Can you give me some instructions?Thank you very much.
