20 years ago
USB device!
I have a usb flash disk, I want to using it on my board, I choose USB Mass storage and SCSI disk and ISA116X driver support in menuconfig. Start uClinux on NIOS II SDK shell, using dmesg, I got these message:
# dmesg
Linux version 2.6.11-uc0 ([email protected]) (gcc version 3.4.6)# 11 Sa
t Apr 15 17:52:30 CST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 008F0000
On node 0 totalpages: 2048
DMA zone: 2048 pages, LIFO batch:1
Normal zone: 0 pages, LIFO batch:1
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6188k/8192k RAM, 0k/0k ROM (1334k kernel code, 551k data)
Calibrating delay loop... 24.72 BogoMIPS (lpj=123648)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler deadline registered
dmfe_probe:eth0, 50000 Khz Nios
<DM9000> eth0 I/O: 80900090, VID: 90000a46
ADDR: 00:07:ed:00:00:00
dmfe_probe:eth1, 50000 Khz Nios
Linux video capture interface: v1.00
116x: driver isp116x-hcd, 08 Apr 2005
116x: ISP116x Host Controller, irq 4
isp116x-hcd isp116x-hcd: new USB bus registered, assigned bus number 1
116x: Invalid chip ID 3630
isp116x-hcd isp116x-hcd: USB bus 1 deregistered
116x: init error, -19
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
NET: Registered protocol family 17
Freeing unused kernel memory: 436k freed (0x15e000 - 0x1ca000)#
I plug my usb flash disk in my board usb host port, there is no message appear!
How could I to find the usb disk?
    Hello...
    Please Help as I think you people can..
    I am curently working on IP08 board made by Rowetel and it has BF532 and ISP1362 controller for USB. The Problem I am facing is that I am able to use normal USB Mass storage devices they are detected by the system (uClinux 2009 dist).
    i.e. it prints a message saying usb 1-2: new full speed USB device using isp1362-hcd and address 2
    usb 1-2: configuration# 1 chosen from 1 choice
    scsi0 : SCSI emulation for USB Mass Storage devices
    usb 1-2: New USB device found, idVendor=0951, idProduct=160b
    usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    usb 1-2: Product: DataTraveler2.0
    usb 1-2: Manufacturer: Kingston
    usb 1-2: SerialNumber: 0802101904166
    uncorrectable error : <3>uncorrectable error : <3>uncorrectable error : <3>unco2
    sd 0:0:0:0: [sda] 7806847 512-byte hardware sectors: (3.99 GB/3.72 GiB)
    sd 0:0:0:0: [sda] Write Protect is off
    sd 0:0:0:0: [sda] Assuming drive cache: write through
    sda: sda1
    sd 0:0:0:0: [sda] Attached SCSI removable disk
    and at this point
    root:/proc/bus/usb> cat devices
    T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
    B: Alloc= 0/900 us ( 0%),# Int= 0,# Iso= 0
    D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64# Cfgs= 1
    P: Vendor=1d6b ProdID=0001 Rev= 2.06
    S: Manufacturer=Linux 2.6.28.10-ADI-2009R1.1 isp1362-hcd
    S: Product=ISP1362 Host Controller
    S: SerialNumber=isp1362-hcd.0
    C:*# Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
    I:* If#= 0 Alt= 0# EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
    E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
    T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
    D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64# Cfgs= 1
    P: Vendor=0951 ProdID=160b Rev= 1.00
    S: Manufacturer=Kingston
    S: Product=DataTraveler2.0
    S: SerialNumber=0802101904166
    C:*# Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
    I:* If#= 0 Alt= 0# EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
    E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    But when I try to attach MP3 Player or Nokia Phone it does not even show symptoms of being attached to usb port. Although I have compiled ISP1362-HCD and enabled the cdc-acm support as well. Kindly guide me whether it is feasible or not, If yes then where the problem is.
    Hi.I have a DE3 board.I want to use the USB interface in the DE3 board,How can I do it.I add ISP1760 to my design and compile successed.Is there anything should be modified?Can you give me some instructions?Thank you very much.
