20 years agoUSB device!
I have a usb flash disk, I want to using it on my board, I choose USB Mass storage and SCSI disk and ISA116X driver support in menuconfig. Start uClinux on NIOS II SDK shell, using dmesg, I got these...
20 years agoI am very happy with the success of you both. Help each other, please. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
If you want to mount Linux disk partition or others, you can enable them in kernel config, file system -> ext2 or ext3 or others . You should enable only the options which you will use. But don't enable too much, the kernel size will grow, take more memory and take longer time to boot.
