20 years agoUSB device!
I have a usb flash disk, I want to using it on my board, I choose USB Mass storage and SCSI disk and ISA116X driver support in menuconfig. Start uClinux on NIOS II SDK shell, using dmesg, I got these...
20 years ago --- Quote Start --- originally posted by goral@Apr 28 2006, 11:52 AM hi, hippo :
this message i've got
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
# fdisk -l /dev/sda
disk /dev/sda: 134 mb, 134070272 bytes
2 heads, 32 sectors/track, 4091 cylinders
units = cylinders of 64 * 512 = 32768 bytes
device boot start end blocks id system
/dev/sda1 1 4090 130864 4 fat16 <32m# mount -t vfat /dev/sda1 /mnt
mount: mounting /dev/sda1 on /mnt failed: no such device# --- Quote End --- After I try to operate like sda1 as sda: <div class='quotetop'>QUOTE </div> --- Quote Start --- # fdisk -l /dev/sda1 Disk /dev/sda1: 134 MB, 134004736 bytes 5 heads, 52 sectors/track, 1006 cylinders Units = cylinders of 260 * 512 = 133120 bytes Device Boot Start End Blocks Id System /dev/sda1p1 ? 6546149 12813521 814758329+ 74 Unknown Partition 1 has different physical/logical beginnings (non-Linux?): phys=(288, 110, 36) logical=(6546148, 2, 41) Partition 1 has different physical/logical endings: phys=(366, 104, 37) logical=(12813520, 1, 31) Partition 1 does not end on cylinder boundary. /dev/sda1p2 ? 5116094 7189079 269488144 65 Unknown Partition 2 has different physical/logical beginnings (non-Linux?): phys=(107, 121, 32) logical=(5116093, 0, 13) Partition 2 has different physical/logical endings: phys=(10, 121, 13) logical=(7189078, 3, 44) Partition 2 does not end on cylinder boundary. /dev/sda1p3 ? 2073037 7451356 699181456 53 Unknown Partition 3 has different physical/logical beginnings (non-Linux?): phys=(345, 32, 19) logical=(2073036, 0, 32) Partition 3 has different physical/logical endings: phys=(324, 77, 19) logical=(7451355, 0, 3) Partition 3 does not end on cylinder boundary. /dev/sda1p4 ? 15035072 15035323 32669+ bb Unknown Partition 4 has different physical/logical beginnings (non-Linux?): phys=(65, 1, 0) logical=(15035071, 2, 3) Partition 4 has different physical/logical endings: phys=(96, 0, 7) logical=(15035322, 3, 29) Partition 4 does not end on cylinder boundary. Partition table entries are not in disk order# [/b] --- Quote End --- Maybe the disk wasn't work? Could I try other device to replcae the usb flash disk to test the ISP1362? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14792)</div> [/b] --- Quote End --- From your result, the isp1362 should work. The usb disk is detected, and partition table is correct. did you enable vfat in kernel config as in step16 of the buildroot guide?
