20 years agoUSB device!
I have a usb flash disk, I want to using it on my board, I choose USB Mass storage and SCSI disk and ISA116X driver support in menuconfig. Start uClinux on NIOS II SDK shell, using dmesg, I got these...
20 years agofor kernel config,
drivers->scsi->scsi disk support drivers->usb->usb devices filesystem, usb mass storage . and you need vfat support as in CF drive. This is the log of my usb host on pci, <div class='quotetop'>QUOTE </div> --- Quote Start --- hub 8-0:1.0: USB hub found hub 8-0:1.0: 2 ports detected Initializing USB Mass Storage driver... scsi0 : SCSI emulation for USB Mass Storage devices usbcore: registered new driver usb-storage USB Mass Storage support registered. Freeing unused kernel memory: 372k freed (0x17e000 - 0x1da000) init started: BusyBox v1.2.0-pre0 (2006.04.26-14:48+0000) multi-call binary BusyBox v1.2.0-pre0 (2006.04.26-14:48+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # Vendor: Multi Model: Flash Reader Rev: 1.00 Type: Direct-Access ANSI SCSI revision: 00 SCSI device sda: 1997312 512-byte hdwr sectors (1023 MB) sda: assuming Write Enabled sda: assuming drive cache: write through SCSI device sda: 1997312 512-byte hdwr sectors (1023 MB) sda: assuming Write Enabled sda: assuming drive cache: write through sda: sda1 Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0[/b] --- Quote End ---
