20 years agoUSB device!
I have a usb flash disk, I want to using it on my board, I choose USB Mass storage and SCSI disk and ISA116X driver support in menuconfig. Start uClinux on NIOS II SDK shell, using dmesg, I got these...
20 years agohi all
I have the same problem,too. this is my booting messages.................... uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 008F0000 Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 5904k/8192k RAM, 0k/0k ROM (1612k kernel code, 580k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart dmfe_probe:eth0, 50000 Khz Nios <DM9000> eth0 I/O: 80900090, VID: 90000a46 ADDR: 00:07:ed:00:00:00 dmfe_probe:eth1, 50000 Khz Nios usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362_hc_reset: Clock not ready after 20ms isp1362-hcd isp1362-hcd: can't reset init error, -19 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. i2c /dev entries driver NET: Registered protocol family 2 IP route cache hash table entries: 128 (order: -3, 512 bytes) TCP established hash table entries: 512 (order: -1, 2048 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP reno registered TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 Freeing unused kernel memory: 448k freed (0x1a6000 - 0x215000) init started: BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) multi-call binary BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # cd /proc# more mounts rootfs / rootfs rw 0 0 proc /proc proc rw 0 0 sysfs /sys sysfs rw 0 0# mount -t vft /dev/hda /mount mount: Mounting /dev/hda on /mount failed: No such file or directory# when I plug my usb disk on my uClinux then no response . so , i can't mount my usb flash disk.......... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif thank in advance! jay
