21 years agousb build error! help me :)
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif today i setup uclinux1.2 again,and modified kconfig files. but when i build the kernel ,here were so much errors : Error...
21 years agoWhen you copied over the driver, did you modify the Kconfig and Makefile so as to only build the new sl811-hcd driver? The old one will complain about the dma functions which aren't present, but if you don't try to compile the old one at all, no problems. :-)
As for building sl811-hcd.o.d, I have no idea. Try posting the relevant portion of your modified Kconfig and Makefile files.
