20 years agoUSB-Blaster under Linux?
Hi all, I've tried getting the NIOS IDE to work under Linux. Everything's fine up to the point where I want to download my code to the eval board (Cyclone 1c20). Apparently the USB Blas...
20 years agoHi Slacker,
Thanks for the info. That's exactly what was needed for the USB-Blaster and I can now connect. However, I always get a SYSID mismatch and when I bypass the SYSID checking the download works ok but it hangs saying "Leaving target processor paused". Again, the Windows machine works with the same .SOF and I also programmed it into the EPCS thinking I might be able to work around it that way but it still doesn't work. Any hints very welcome. Next I'll try programming everything into ( SOF into EPCS, program into flash) so I don't need any download and then see if I can break in with the debugger. Andrew
