21 years agoUSB Blaster replace/repair
I have a RevB USB-blaster (yellow cable) that has never worked (maybe once every 30 tries). Signal integrity on TCLK etc is very bad compared to ByteBlasterII. Replacing the long yellow flex ...
21 years agofrom ALtera support "FIND ANSWERS"
Problem Are there any known errors in the Stratix and Cyclone Configuration chapters with reference to the external pull-down resistor value recommended for the JTAG TCK signal? Solution Yes. The JTAG TCK pull-down resistor value is incorrectly specified as 10k-ohms in the Stratix and Cyclone Configuration chapters. The correct external pull-down resistor value is 1k-ohm. This stronger resistor ensures that the TCK signal is biased at a logic low level despite the weak internal pull-up on this pin. The internal pull-up ranges from 20k-ohms to 40k-ohms across process, voltage and temperature. Future versions of the Stratix and Cyclone Handbooks will be updated accordingly.
