17 years agoUSB Blaster Fedora 10
HI,
Here is what I did to get USB blaster to work and get the DE1 developkment board detected. I used this Altera link http://www.altera.com/support/software/dri...-usb_b-lnx.html (http://www.altera.com/support/software/drivers/dri-usb_b-lnx.html) and did the following 1. Check if USB is installed (Fedora newer version have this mounted by default)# ls -l /proc/bus/usb/ total 0 dr-xr-xrwx 2 root root 0 2009-07-30 17:01 001 dr-xr-xrwx 2 root root 0 2009-07-30 17:01 002 -r-xr-xrwx 1 root root 0 2009-07-30 18:21 devices => two usb controllers (0,1) are in my machine. If there is none, check this link http://linuxusbguide.sourceforge.net/usb-g...1.0.9/x180.html (http://linuxusbguide.sourceforge.net/usb-guide-1.0.9/x180.html) 2. Check# ls -l /etc/hotplug.d/usb/ total 16 -rw-r--r-- 1 root root 4547 2007-06-26 23:54 gpsd.hotplug -rw-r--r-- 1 root root 1162 2009-07-30 18:19 gpsd.usermap Edit the .usermap file and add the lines as specified on Altera's link (Driver Setup on RedHat Linux Enterprise 4 and Below# 1) 3. Create a file /etc/hotplug.d/usb/usbblaster and do as in# 2 on http://www.altera.com/support/software/dri...-usb_b-lnx.html (http://www.altera.com/support/software/drivers/dri-usb_b-lnx.html) 4. Change permissions chmod +x /etc/hotplug.d/usb/usbblaster chmod -R 557 /proc/bus/usb 3. Plugin the usb for the dev board and run # jtagconfig 1) USB-Blaster [USB 2-1.6] 020B30DD EP2C15/20 Confirm this by running this command as normal user in another terminal. If ok, please run Quartus -> Programmer to see the device in there too. Please add your experiences for any variations in your linux kernel/version. I saw the directory /etc/hotplug.d instead of the expected /etc/hotplug in Fedora 10. Btw, the kernel I have is uname -a Linux smart1.workhorse.com 2.6.27.25-170.2.72.fc10.i686.PAE# 1 SMP Sun Jun 21 18:51:33 EDT 2009 i686 athlon i386 GNU/Linux ThanksNo RepliesBe the first to reply
