19 years agoUSB-Blaster 2.6 kernel problem
Hi , I have a problem with USB-BLASTER cable. I work with SUSE 10.2 linux 2.6 kernel for the education environement. ByteBlaster work OK, but USBBlaster on my DE2 board d'not work. ud...
19 years agoActually, FC6 might detect jtag without changing udev rules. The jtag got detected sometime with root account. I have to disable SELinux to run nios2-configure-sof. I tried changing the mode to 0666 in 50-udev.rules to get user access. Sometime it works, but mostly fails.
There is no /etc/hotplug dir in FC6. The /etc/udev rules changed a lot from RHEL4. In FC6, the udev add the jtag as /dev/bus/usb/004/002 dev, the bus number may be different for different usb ports. I think you should not name the dev as "usbblaster".
