12 years agoUSB 2.0 Slave HwLib
Hello! I am developing an application for the Cyclone V where the board is connected to a Windows PC as a USB 2.0 slave. I have following wishes: Use case 1: The board collects data and pr...
12 years agoUSB -- very big mountain, Altera go to there in last time!
Meanwhile you may try to use many RTOSes with 1 thread -- suddently some have USB API ? Or if drag over from Linux sources to alt_usb.c ?.. If works there :) P.S. On Altera CV board where located HPS USB 2.0 OTG connector ? I see and use only 2 mini-USBs: for internal USB-Blaster and RS-port. And the possibility to connect as slave flash device to PC is very need !
