20 years agoUSB 2.0 ISP1761
Hi all! Does anybody use the ISP1761 in a NIOS-project yet? I've heard that there are drivers, but I've never tested it. Is there any experience? Thank you! e-tricky
20 years ago --- Quote Start --- originally posted by e-tricky@Oct 25 2006, 11:54 PM that sounds good!
@hippo: would you share your schematic to connect the isp1761 to the santa cruz header and send it to me? that would save a plenty of time for me.
i have additional questions, maybe you can help me:
i'm new with usb, how did you test the transfer rate of 10mb/s? did you use a loop or an other device? how to communicate from a windows pc to the nios system via usb? is there some sample code?
i would be very happy to get more information about this!
thank you!
e-tricky
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18909)
--- quote end ---
--- Quote End --- It was based on http://www.nxp.com/acrobat/applicationnotes/an10037_4.pdf (http://www.nxp.com/acrobat/applicationnotes/an10037_4.pdf) use 16bits data mode, shared host/device dma and irq and add a latch from data bus to generate chip address. pull high data[31:16] with a single R. a[17] <= 0; a[16:1] <= data[15:0] then you have a data port and reg adress port. You may find other useful doc on their site. I wrote a simple test program (without Linux) to do the transcations directly to a fast USB thumb disk. I will try Linux later, and I will share with you. The USB driver is not trivial. But using Linux is easy, they hide the details.
