20 years agoUSB 2.0 ISP1761
Hi all! Does anybody use the ISP1761 in a NIOS-project yet? I've heard that there are drivers, but I've never tested it. Is there any experience? Thank you! e-tricky
20 years agoIt is not difficult to connect ISP1761 to 40 pins headers on the dev board.
You can use it at 16 bits mode. I have built the hardware, basic access is OK. I have tried it up to 10MB/sec sustained transfer rate using a custom DMA master. But I didn't have time to try uClinux yet. Bernard ported the driver to a PXA255 running 2.6.17. I am working on the new uClinux-dist-20060803, which is 2.6.17. I will release the update of uClinux-dist soon.
