20 years agoUSB 2.0 ISP1761
Hi all! Does anybody use the ISP1761 in a NIOS-project yet? I've heard that there are drivers, but I've never tested it. Is there any experience? Thank you! e-tricky
20 years agoI will use the ISP1761 in a project. Some Sourcecode is available from Sourceforge. The code supports their evaluation board which has a PCI interface. In my case I cannot use this code directly because I will connect the chip directly to the Nios without PCI. I have no HW yet, so it will take some time for me to start the driver.
I found following on Nios Wiki http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Read in the nios wiki (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/usbhost) about USBhost, At the bottom there is a link provided for the ISP1761, I had no time to evaluate this yet, but it seems that it is the diff to the PCI sources. isp 1761 (http://dagobah.ucc.asn.au/isp1761/)
