15 years agoURGENT: IOWR problem
hello, i have a problem writing data into sdram on de2 board. when i generate 10 numbers (0-9) and write into sdram, it works fine. if i generate 100 numbers (0-99), it has a problem. here is my code...
15 years agoDaixiwen: Thanks for the info. I am new, so i am not sure there is some other ways to write to SDRAM? Can you please provide me with more info or maybe tutorials? thanks!
Cris72: Thanks for the info! I plan to use flash memory but I dont know the setting in SOPC, not sure of the verilog code for the signal connection and i dont know how to access the flash memory? is it possible that you help me out with some basic info? thanks!
