20 years agoUpgrading Nios Software - external flash
Dear all, I would like to upgrade my NIOS code by RS232. The NIOS runs from external memory. This is my procedure: - I transfer the .elf file to the .flash file by the instruction el...
20 years agoMaybe you already tried this, but did you checked if there is any exception running because of some unimplemented instruction? ... in that case you'll jump in flash also if interrupts are disabled...
PJ
