20 years agoUpgrading Nios Software - external flash
Dear all, I would like to upgrade my NIOS code by RS232. The NIOS runs from external memory. This is my procedure: - I transfer the .elf file to the .flash file by the instruction el...
20 years agoScott,
I have off course also used the debugger. I saw that after the sector erase the code goes on. So, the instruction after the sector erase is called. (also all the other following instructions) The only thing I can learn from the debugger is that they have no effect. That why I make use of LEDs, to see that the instructions have any result Regards Karel
