20 years agoUpgrading Nios Software - external flash
Dear all, I would like to upgrade my NIOS code by RS232. The NIOS runs from external memory. This is my procedure: - I transfer the .elf file to the .flash file by the instruction el...
20 years ago> 3 .exceptions 00000328 01000020 00009c00 00009cd4 2**2
> CONTENTS, ALLOC, LOAD, READONLY, CODE Ok, so I'll assume this is in flash memory. Next question: Do you have a system timer and do you disable interrupts when you are programming the flash? --Scott
