20 years agoUpgrading Nios Software - external flash
Dear all, I would like to upgrade my NIOS code by RS232. The NIOS runs from external memory. This is my procedure: - I transfer the .elf file to the .flash file by the instruction el...
20 years agoInfo about the sections
Sections: Idx Name Size VMA LMA File off Algn 0 .entry 00000020 00000000 00000000 000000d4 2**5 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .text 0000961c 00000020 00000020 000000f4 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 2 .rodata 000005c4 0000963c 0000963c 00009710 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 3 .exceptions 00000328 01000020 00009c00 00009cd4 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 4 .rwdata 00001cdc 01000348 00009f28 00009ffc 2**2 CONTENTS, ALLOC, LOAD, DATA, SMALL_DATA 5 .bss 0000216c 01002024 01002024 0000c01c 2**2 ALLOC, SMALL_DATA 6 .FLASHCtrl 00000000 0000bc04 0000bc04 0000c01c 2**0 CONTENTS 7 .OnChipMem 00000344 01004190 0000bc04 0000bcd8 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 8 .comment 000007ba 00000000 00000000 0000c01c 2**0 CONTENTS, READONLY 9 .debug_aranges 00000618 00000000 00000000 0000c7d8 2**3 CONTENTS, READONLY, DEBUGGING 10 .debug_pubnames 00000df8 00000000 00000000 0000cdf0 2**0 CONTENTS, READONLY, DEBUGGING 11 .debug_info 0000ef78 00000000 00000000 0000dbe8 2**0 CONTENTS, READONLY, DEBUGGING 12 .debug_abbrev 00002e88 00000000 00000000 0001cb60 2**0 CONTENTS, READONLY, DEBUGGING 13 .debug_line 0000ba73 00000000 00000000 0001f9e8 2**0 CONTENTS, READONLY, DEBUGGING 14 .debug_frame 00000e74 00000000 00000000 0002b45c 2**2 CONTENTS, READONLY, DEBUGGING 15 .debug_str 00000d7c 00000000 00000000 0002c2d0 2**0 CONTENTS, READONLY, DEBUGGING 16 .debug_alt_sim_info 00000010 00000000 00000000 0002d04c 2**2 CONTENTS, READONLY, DEBUGGING 17 .debug_ranges 00000030 00000010 00000010 0002d05c 2**0 CONTENTS, READONLY, DEBUGGING
