20 years agoUpgrading Nios Software - external flash
Dear all, I would like to upgrade my NIOS code by RS232. The NIOS runs from external memory. This is my procedure: - I transfer the .elf file to the .flash file by the instruction el...
20 years agoHi pfab,
My NIOS code is running from external flash memory. What I'm doing is the follow. I first of all receive the whole bin file from RS232. I save this file into an free flash sector. This works fine. So, the following thing I have to do is copy this flash sector to the flash sector my nios core is running from. Therefore I have written a routine that is placed in internal memory by the section habdler: extern void UpdataSoftware(void)__attribute__((section(".OnChipMem"))); void UpdateSoftware(void) { alt_irq_context count3; count3 = alt_irq_disable_all(); for(FlashAd = 0x0000000; FlashAd < 0x0140000; FlashAd += 0x0020000) { EraseFlashSector(FlashAd); } /* HERE MY PROGRAM FAILS. I erase the flash sector 0 (sector from which the nios is running from). The instruction "EraseFlashSector" is also placed in internal memory*/ unsigned int FlAdW; unsigned int FlAdR; unsigned char Byte; for(FlAdW = 0x0000000,FlAdR = 0x0640000;FlAdW < 0x0140000; FlAdR++,FlAdW++) { unsigned char * ReadFlashData = (unsigned char*)(FlAdR); Byte = *ReadFlashData; WriteFlash(Byte,FlAdW); } UART1_T('O'); UART1_T('K'); } Regards Karel
