19 years agoUpgrade via Ethernet
http://www.altera.com/literature/an/an346.pdf (http://www.altera.com/literature/an/an346.pdf) is a reference document about upgrade thru Ethernet link. I'm looking how to do that with more detail...
19 years agoahhh okay ...
then you should be able to update the serial config device via nios. you have ethernet, memory, nios ... and hopefully a running system. but if your update of the serial device fails and you try to restart, do not have a running system and need a blaster. regards.
