19 years agoUpgrade via Ethernet
http://www.altera.com/literature/an/an346.pdf (http://www.altera.com/literature/an/an346.pdf) is a reference document about upgrade thru Ethernet link. I'm looking how to do that with more detail...
19 years agoHi Oleg,
i am quit not shure about your target design. Does ist consist : FPGA Flash SRAM Ethernet (for example) and what source of your fpga image (inside Flash oder epcs) ? Of you have an epcs then you can of course update your epcs via nios, but no fall back option if update is corrupted if you have the image inside a flash then you need some kind of external configuration device that reads out the image from the flash an stores it into the fpga. Regards Michael
