20 years agoUpgrade sdram chip to 16MB for DE2 dev...
Hi hippo
My sdram memory is 8MB that not enough free memory to run some app program on uClinux,and i want to replace it .Recently ,I already find IS42S16800B sdram chip(16MB) that match all pins of IS42S16400 for DE2 board. I can know the pin 36 don't connect to FPGA chip from sdram PCB schematic . So, i only select 16MB for sdram chip, but I have not to buy it yet . This is diference between the IS42S16400 chip and the IS42S16800B chip,as following: IS42S16400 sdram chip(1Mx16x4bnaks): ==>8MB 1.Row addr input :A0~A11 (12 bit) 2.Column addr input: A0~A7 (8 bit) IS42S16800B sdram chip(2Mx16x4banks): ==>16MB 1.Row addr input :A0~A11 (12 bit) 2.Column addr input: A0~A8 (9 bit) Do you think that i can directly replace it ? or give me some advices . Thx !22 Replies
What kind of problems you have in linux-2.6.16-uc0 ?
You can change the initramfs path of 2.6.16.1 to that of romfs. Then you can cross check. - Altera_Forum
--- Quote Start --- originally posted by hippo@Jun 5 2006, 09:27 AM what kind of problems you have in linux-2.6.16-uc0 ?you can change the initramfs path of 2.6.16.1 to that of romfs.
then you can cross check.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15921)
--- quote end ---
--- Quote End --- hi hippo Sorry, this is my mistake about compiling app problem. and don't need to add "make" and "make romfs" are two steps for rebuild kernel.
