19 years ago
Upgrade sdram chip to 16MB for DE2 dev...
Hi hippo
My sdram memory is 8MB that not enough free memory to run some app program on uClinux,and i want to replace it .Recently ,I already find IS42S16800B sdram chip(16MB) that match all pins of IS42S16400 for DE2 board. I can know the pin 36 don't connect to FPGA chip from sdram PCB schematic . So, i only select 16MB for sdram chip, but I have not to buy it yet .
This is diference between the IS42S16400 chip and the IS42S16800B chip,as following:
IS42S16400 sdram chip(1Mx16x4bnaks): ==>8MB
1.Row addr input :A0~A11 (12 bit)
2.Column addr input: A0~A7 (8 bit)
IS42S16800B sdram chip(2Mx16x4banks): ==>16MB
2.Column addr input: A0~A8 (9 bit)
Do you think that i can directly replace it ?
or give me some advices .
Thx !
    What kind of problems you have in linux-2.6.16-uc0 ?
    You can change the initramfs path of 2.6.16.1 to that of romfs.
    Then you can cross check.
    --- Quote Start ---
    originally posted by hippo@Jun 5 2006, 09:27 AM
    what kind of problems you have in linux-2.6.16-uc0 ?
    you can change the initramfs path of 2.6.16.1 to that of romfs.
    then you can cross check.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15921)
    --- quote end ---
    --- Quote End ---
    hi hippo
    Sorry, this is my mistake about compiling app problem.
    and don&#39;t need to add "make" and "make romfs" are two steps for rebuild kernel.
