20 years agoUpgrade sdram chip to 16MB for DE2 dev...
Hi hippo My sdram memory is 8MB that not enough free memory to run some app program on uClinux,and i want to replace it .Recently ,I already find IS42S16800B sdram chip(16MB) that match all pin...
20 years ago --- Quote Start --- originally posted by hippo@Jun 4 2006, 04:28 AM yum install ncurses-devel
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15862)
--- quote end ---
--- Quote End --- hi hippo I meet the same problem about installing ncurses, again. Why i can't install ncurses sucessfully ? Do you think what is problem ? Thx ! <div class='quotetop'>QUOTE </div> --- Quote Start --- [root@localhost uClinux-dist-test]# yum install ncurses-devel Setting up Install Process Setting up repositories updates-released 100% |=========================| 951 B 00:00 extras 100% |=========================| 1.1 kB 00:00 base 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files Parsing package install arguments Nothing to do [root@localhost uClinux-dist-test]# exit exit [faye@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in make -C /home/faye/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/faye/uClinux-dist-test/config/scripts/lxdialog' /bin/sh: cc: command not found >> Unable to find the Ncurses libraries. >> >> You must have Ncurses installed in order >> to use 'make menuconfig' make[1]: *** [ncurses] Error 1 make[1]: Leaving directory `/home/faye/uClinux-dist-test/config/scripts/lxdialog' make: *** [menuconfig] Error 2 [faye@localhost uClinux-dist-test]$[/b] --- Quote End ---
