20 years agoUpgrade sdram chip to 16MB for DE2 dev...
Hi hippo My sdram memory is 8MB that not enough free memory to run some app program on uClinux,and i want to replace it .Recently ,I already find IS42S16800B sdram chip(16MB) that match all pin...
20 years ago --- Quote Start --- originally posted by hippo@Jun 3 2006, 06:56 PM yes, you can replace it.
you need to update your sdram component in sopc builder.
use the new uclinux-dist-test approach can save around 1-2mb , compared to old buildroot guide.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15846)
--- quote end ---
--- Quote End --- hi hippo Thank you ! I have add new user accounton linux platform that use the uClinux-dist-test. and i got error info about ncurses. <div class='quotetop'>QUOTE </div> --- Quote Start --- [faye@localhost uClinux-dist-test]$ ls bin Documentation linux-2.0.x openswan uClibc config freeswan linux-2.4.x README uClinux-dist.diff.gz config.in include linux-2.6.x SOURCE user COPYING lib Makefile tools vendors [faye@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in make -C /home/faye/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/faye/uClinux-dist-test/config/scripts/lxdialog' /bin/sh: cc: command not found >> Unable to find the Ncurses libraries. >> >> You must have Ncurses installed in order >> to use 'make menuconfig' make[1]: *** [ncurses] Error 1 make[1]: Leaving directory `/home/faye/uClinux-dist-test/config/scripts/lxdialog' make: *** [menuconfig] Error 2 [faye@localhost uClinux-dist-test]$ su Password: [root@localhost uClinux-dist-test]# yum install ncurses Setting up Install Process Setting up repositories updates-released 100% |=========================| 951 B 00:00 extras 100% |=========================| 1.1 kB 00:00 base 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 384 kB 00:22 updates-re:# ################################################# 1073/1073 Added 5 new packages, deleted 1 old in 5.99 seconds primary.xml.gz 100% |=========================| 921 kB 00:05 extras :# ################################################# 2680/2680 Added 108 new packages, deleted 7 old in 17.57 seconds Parsing package install arguments Nothing to do [root@localhost uClinux-dist-test]# exit exit [faye@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in make -C /home/faye/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/faye/uClinux-dist-test/config/scripts/lxdialog' /bin/sh: cc: command not found >> Unable to find the Ncurses libraries. >> >> You must have Ncurses installed in order >> to use 'make menuconfig' make[1]: *** [ncurses] Error 1 make[1]: Leaving directory `/home/faye/uClinux-dist-test/config/scripts/lxdialog' make: *** [menuconfig] Error 2 [faye@localhost uClinux-dist-test]$[/b] --- Quote End --- How to install ncurses that is correctly ? THX !
