21 years agoUpdating hardware defs in eCos
Hi! I have build an eCos library, and I've been using it successfully. The fact is that I need to add some peripherals to the Nios2, and I would like to preserve the current eCos con...
21 years agoThank you!
That's what I've been doing until now, but without changing the hardware defs. Only in order to change some eCos params I read in the eCos for NiosII basic tutorial that if you change your hardware defs, you should open the nios2configtool with the new ptf and configure it again, so I was afraid that if I tried to re-open the new ptf with the previous project, it would assign the addresses of the old project (somewhere saved in the .ecc). Thank you again! aLeX
