20 years agoUpdating EPCS
Is it possible to update the software code stored in Alteras EPCS flash? I know these devices are basically SPI flash, but the Altera device has dedicated pins connecting it. Thanks in advance,...
20 years agoI'd read this document since it shows you how to program hardware and software contents into the EPCS device (or CFI flash):
http://www.altera.com/literature/ug/ug_nio..._programmer.pdf (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf) If you are looking to do this "on the fly" then you can use the method slacker mentioned below to access the device.
