20 years agoUpdate to buildroot toolchain for nios2
UPDATE : This post is out of date. Please follow the new one,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) Vapier has kindly incorporated patches from marc into the buildroot. Try out the lastest update of buildroot/uClibc/busybox with svn now or daily snapshot (tommorow).svn co svn://uclibc.org/trunk/buildroot36 Replies
if it stops at , crt0.o: No such file
cd ~/buildroot/build_nios2/staging_dir/lib ln -s crt1.o crt0.o cd ~/buildroot make - Altera_Forum
This project is getting to close. It is moved to "Post Your Own IP".
Please check this, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) I shall move to another topic, "sync up the kernel to 2.6.15". Stay tune. - Altera_Forum
thanks to hippo,after those modify,compile completed.
and I will try to build kernel and fs. may you guide me the follow things? --- Quote Start --- originally posted by hippo@Jan 11 2006, 09:34 AM if it stops at , crt0.o: no such filecd ~/buildroot/build_nios2/staging_dir/lib
ln -s crt1.o crt0.o
cd ~/buildroot
make
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12139)
--- quote end ---
--- Quote End ---
good news.
the symlink should be there already, so you do not need to add it by hand. check the update on "Post Your Own IP". http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) There are informations about kernel and apps. - Altera_Forum
Alex,
I have checked your dirs and mesages. The gcc was not built. [buildroot/toolchain_build_nios2]$ ls # should be bin ccache-2.4 gcc-3.4.3 linux binutils-2.15 elf2flt gcc-3.4.3-final uClibc binutils-2.15-build fakeroot-1.2.13 gcc-3.4.3-initial uClibc_dev maybe some files mixed up. Please remove old buildroot dir.
Check the update in http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) Follow the new steps, download all files again and try again.rm -rf buildroot - Altera_Forum
hippo:
I installed toolschain in another PC with red hat linux 8.0 follow your method . But still failed. I got the similarly erro informathion . I think maybe the toolschain dissonant the red hat linux OS. I decided use fedora core 4 install the toolschain.
