20 years agoUpdate to buildroot toolchain for nios2
UPDATE : This post is out of date. Please follow the new one, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) Vapier h...
20 years agohi hippo:
tar jxf buildroot-snapshot.tar.bz2 cd buildroot mkdir dl cd dl unzip ...../configs.zip cp ..../gcc*bz2 ..../*snapshot*bz2 . # copy those files into dl cd buildroot make defconfig cp dl/buildroot.config .config make I am according to your method install toolchain,but make failed. The erro information : make -C /usr/local/nios2_toolchain/buildroot/toolchain_build_nios2/uClibc PREFIX=/usr/local/nios2_toolchain/buildroot/toolchain_build_nios2/uClibc_dev/ DEVEL_PREFIX=/usr/ RUNTIME_PREFIX=/usr/local/nios2_toolchain/buildroot/toolchain_build_nios2/uClibc _dev/ HOSTCC="gcc" pregen install_dev; make[1]: /usr/local/nios2_toolchain/buildroot/build_nios2/staging_dir/bin/nios2- linux-uclibc-gcc: Command not found make[1]: Entering directory `/usr/local/nios2_toolchain/buildroot/toolchain_buil d_nios2/uClibc' make[1]: /usr/local/nios2_toolchain/buildroot/build_nios2/staging_dir/bin/nios2- linux-uclibc-gcc: Command not found BBmake -C extra/config conf make[2]: /usr/local/nios2_toolchain/buildroot/build_nios2/staging_dir/bin/nios2- linux-uclibc-gcc: Command not found make[2]: Entering directory `/usr/local/nios2_toolchain/buildroot/toolchain_buil d_nios2/uClibc/extra/config' tack-protector -S -o /dev/null -xc /dev/null > /dev/null 2>&1; then echo "-fno-s tack-protec衜ake[2]: /usr/local/nios2_toolchain/buildroot/build_nios2/staging_di r/bin/nios2-linux-uclibc-gcc: Command not found ?B?Bmake[2]: *** No rule to make target `|', needed by `../../extra/config/c onf.o'. Stop. make[2]: Leaving directory `/usr/local/nios2_toolchain/buildroot/toolchain_build _nios2/uClibc/extra/config' make[1]: *** [extra/config/conf] Error 2 make[1]: Leaving directory `/usr/local/nios2_toolchain/buildroot/toolchain_build _nios2/uClibc' make: *** [/usr/local/nios2_toolchain/buildroot/toolchain_build_nios2/uClibc/.co nfigured] Error 2 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif please help me check it.Thanks.
