20 years agoUpdate to buildroot toolchain for nios2
UPDATE : This post is out of date. Please follow the new one, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) Vapier h...
20 years agoYou may write your question in chinese here.
A. the patch is incorrect between first and second file. Just apply the orginal patch without the modification. There will be only one fail in the first part. then edit the file buildroot/toolchain/Config.in with an editor on Linux. add the line for elf2flt at about line 13. source "toolchain/elf2flt/Config.in" B. You need to install Ncurese libraries to your Linux for buildroot. If you use slackware, it is in "L" set. File: ncurses-5.3-i386-1.tgz for slackware 9.0 installpkg ncurses-5.3-i386-1.tgz If you use redhat/fedora core File: ncurses-5.4-17.i386.rpm for fc4 rpm -ivh ncurses-5.4-17.i386.rpm or yum ncurses
