20 years agoUpdate to buildroot toolchain for nios2
UPDATE : This post is out of date. Please follow the new one, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) Vapier h...
20 years agoI have tested the new buildroot.
It works now with buildroot-snapshot, uClibc-0.9.28, busybox-snapshot. http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2 (http://buildroot.uclibc.org/downloads/snapshots/buildroot-snapshot.tar.bz2) http://www.uclibc.org/downloads/uclibc-0.9.28.tar.bz2 (http://www.uclibc.org/downloads/uclibc-0.9.28.tar.bz2) http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2 (http://busybox.net/downloads/snapshots/busybox-snapshot.tar.bz2) 1. unpack buildroot , tar jxf buildroot-snapshot.tar.bz2 2. download uClibc-0.9.28 into buildroot/dl dir. # unpack uClibc-0.9.28, tar jxf uClibc-0.9.28.tar.bz2 # remove the line of "default nios2-elf-" from uClibc-0.9.28/extran/Configs/Config.nios2 # repack tar jcf uClibc-0.9.28.tar.bz2 uClibc-0.9.28 3. update buildroot/package/busybox/busybox.configCONFIG_STATIC=y
EXTRA_CFLAGS_OPTIONS="-D__uClinux__ -Dfork=vfork"# CONFIG_START_STOP_DAEMON is not set
CONFIG_FEATURE_2_6_MODULES=y 4. update buildroot/toolchain/uClibc/uClibc.config DL_FINI_CRT_COMPAT=y
COMPAT_ATEXIT=y 5. get the elf2flt patch of marc's into buildroot/dl http://bugs.uclibc.org/file_download.php?f...id=225&type=bug (http://bugs.uclibc.org/file_download.php?file_id=225&type=bug) update the first part of elf2flt.diff Index: buildroot/toolchain/Config.in
--- buildroot/toolchain/Config.in 2006-01-07 16:15:08.000000000 +0800
+++ buildroot/toolchain/Config.in 2006-01-09 09:08:15.000000000 +0800
@@ -10,6 +10,7 @@
source "toolchain/ccache/Config.in"
source "toolchain/gdb/Config.in"
source "toolchain/sstrip/Config.in"
+source "toolchain/elf2flt/Config.in"
comment "Common Toolchain Options" Apply the patch cd buildroot patch -p1 <dl/elf2flt.diff 6. in buildroot dir make menuconfig select nios2, in toolchain option, [ ] Use a daily snapshot of uClibc? [*] Enable elf2flt support? [ ] Include target utils in cross toolchain 7. make, it will make binutils,gcc,uclibc, and fail in busybox 8. update the busybox's buildroot/build_nios2/busybox/Rules.mak, add elf2flt #LDFLAGS+=-nostdlib# LIBRARIES:=$(LIBCDIR)/lib/libc.a -lgcc
LDFLAGS+=-Wl,-elf2flt="-s 16000" -Wl,-v -Wl,-d
LIBRARIES:=-lc -lgcc buildroot/build_nios2/busybox/Makefile, comment out the stripcmd busybox: .depend $(libraries-y)
$(CC) $(EXTRA_CFLAGS) $(LDFLAGS) -o $@ -Wl,--start-group $(libraries-y) $(LIBRARIES) -Wl,--end-group# $(STRIPCMD) $@ 9. cd buildroot/build_nios2/busybox, make menuconfig in "shell->", choose default shell "msh", unselect ash, select "standalone shell". 10. back to buildroot/ make, and it will build busybox 11. copy the buildroot/build_nios2/root to another place, cp -a remove usr/lib,usr/include it is your new root fs now. add a sym-link for initramfs , ln -s /sbin/init init This is the cross compiler for nios2 with default to uClibc, and the root fs with busybox. Thanks a lots, to marc and vapier.
