14 years agoUpdate nios-linux 20100621 buid error
After update nios-linux 20100621, when i make, get error : {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/...
11 years agoSorry to annoy you all but I'm trying to build the uClinux on DE2 Cyclone 2 (an old kit). I've had the same error and as far as I realized this is because the nios-linux version is new (nios2-linux-20120802) so may be it's not compatible with the NO MMU. However, I can't find any old version of this file like nios-linux-20090730 since all the links died. So anyone can show me how to fix the problem or provide with the link to download the old version to test.
Thank you all.
