14 years agoUpdate nios-linux 20100621 buid error
After update nios-linux 20100621, when i make, get error : {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/...
12 years agoMaybe you should build the tool chain like:
cd nios2-linux/toolchain-build git clean -f -x -d# clean on restart make gcc make elf2flt Then,use the new compiler you made. PATH=$PATH:/home/(user name)/nios2-linux/toolchain-build/build/nios2/bin Regards.
