14 years agoUpdate nios-linux 20100621 buid error
After update nios-linux 20100621, when i make, get error : {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/...
13 years ago --- Quote Start --- --- Quote Start --- I am using pre-build toolchain nios2gcc-20080203.tar.bz2 and test-nios2 branches(uClinux-dist and Linux-2.6). --- Quote End --- I can remember that this was the wrong toolchain for systems with mmu. nios2gcc-20080202 prebuilt toolchain was for use with nommu-systems. The error message you posted looks like this is the problem here, too.
